Yes it’s larger than the traxxa$ udr.Sharp looking rig! Based on what I see size comparison wise, it must be bigger then the Traxxas UDR.
They call it 1/6. Don’t know how that’s possible. But the scale sizing on all this stuff doesn’t make sense. IMO it’s larger than a ⅛ scale though.I think it's considered an 1/8 scale. Not sure though.
It’s only money.Part of me is tempted to buy one of these . Maybe next year .
Hey guys. I was going through the manual ordering parts for spares. Well, the rear end doesn't seem to jive with the manual. The lower rear trailing arms and rear diff are different on the truck compared to the manual.
Any one else notice this?
Thanks for sharing! Did you end up buying a brace to fix the flex or did you fabricate one yourself??Here is a running video of my SBR 2.0 from my Youtube channel
NP, there are a couple of things addressing the flex there, while yes I did fabricate a brace, I ended up making one similar to the one sold through Ebay and Etsy, that ties the rear shock tower to the 2 screw points that secure the cross bars just before the spare tire carrier moving towards the back, cutting mine out of carbon fiber plate instead of steel (I preferred the idea of not having to modify any of original parts, in case of breakages, but now I appreciate how it helps to spread out impact shock, since it doesn't get completely rigid). I also reinforced the body (fiber tape and shoe goo), because of where this mounts to the roll cage, most of the flex was very minimal before I even had the brace (but I like running both, because the brace also keeps the body from doing all the heavy lifting, and takes the strain off of those mounting points.Thanks for sharing! Did you end up buying a brace to fix the flex or did you fabricate one yourself??
Yeah, they are 6" OD, but these might be the only option for wheels you have for now, that fit these tires.Hey all, I'm a guest here. I've asked on a few other forums but either no one has an SBR 2.0, or no one's willing to assist.
Would you mind measuring the outer diameter of the SBR 2.0 tires for me?
I'm wondering if they'll fit on a project I'm doing. Thanks for any help on this.
Oh, the project is turning my UDR into an Ultra 4 truck. I'm hoping to find a scale tire that is slightly larger than stock (5.7"), but not too huge so that it doesn't contact the chassis. I think right around 6" will be ideal.
Who said it was 1/5th scale to begin with?Right so these cars are not 1/5 end of story ??? got any gripes?
