Looking to make a dyno with no clue at all ?
Maxportinguk
Anyone got any links to making a dyno for 1/5 2wd and 4wd. I have no idea where to start ?
I made the prototype on 3/4" plywood ! I have quite a bit of mass in the brake disk and axle , it needs some weight to be stable , beside I ran my motor on it and a small light frame is not what you want for these motors IMO.
However the frame can be secured. Aluminum frameing would be much safer then plywood though I would suspect these cars aren't putting enough power to brake wood either.
I've plug checked it a bunch of times , I'll fatten it up once I get the carb rebuilt , broke the damn fuel inlet pipe off the carb. BTW a properly tuned 2 stroke does not always smoke , I ran carts at max tuning for 5 yrs , when tuned to the max power they do not hardly smoke BUT you have to be careful !!!!
we used exhaust gas temp sensors to max out tuning.
