DBXL Losi dbxl e 2.0
Tacoma, WA
Hello all,
I recently purchased a Losi DBXL-E 2.0. I am happy with stock speed, but want to upgrade the motor/esc. I'm not sure whether to go with a castle xlx2 or max5, 800kv or 1100kv. I don't hit big jumps and try to destroy things, I just like to drive it the way it was intended. I have already upgraded the steering with a spektrum brushless servo. I am not concerned with price. Any advice? I would like to keep the pinion between 13t and 14t.
Heat is a function of ambient temp load (gearing) and amp draw (which is linked to load). I'd your just putting around big gears wont kill you, if your full on bashing in grass big gears will heat up the motor fast. Fans can help with this issue. But more or less you need to find the sweet spot for your rig under the conditions your running. Bigger motors can take more load without heating up as fast so I'd go with as big as you can get and gear it how you like for speed/acceleration.
My neighbor has a dbxl-e 2.0 and it hauls ass and has stock esc and motor...if your not looking to go faster than whats the point of changing the combo you have now?
The stock esc is a rebranded max6 and is rated at 160amp(the max5 is rated at 200amp), but they took out some of the programming options. The internal BEC can only be switched between 6v and 8.4v. Most 1/5 servos arw rated for 7.4v. I like to have all the programming options
I am a huge fan of effiency, and that is what I am going for, even if it costs $
Hello all,
What size batteries are you planning on running 8S, 10S?
Just me, I would go with the XLX2 8s ESC and the Castle 1100 kv motor. I have a feeling with that set up if you wanted you could probably run 2 5s in series for 10 s if you wanted to at some point. It will handle 8S with no problems at all. Guys use this set up in their Arrma Limitless's for speed running on 8s.
I know that it will be faster than stock, but if I keep it geared around 13/50 (stock) or 14/50 it shouldn't have any heat issues right?
Buy a temp gun amd check. Theres no hard and fast rule for how your set up is going to react. Its electric you chose the easy path, but it still had its proclivities. Monitor your set up and see how hot it gets. Gear accordingly. You may have to change gearing for how or where your running it, or under gear it and not worry about it, but tbh theres zero point in upgrading everything if your not going to use the extra power on tap. No one but you can honestly answer this question.
My neighbors dbxl gets pretty warm just bombing around. Id look into motor fans as well since its an off road vehicle and the body doesn't really flow air well under it
If you are really concerned about heat and you never wanna worry about it do the 800 but its not worth it IMO with the upgrades you would need
Its not that I am worried about the heat. This is uncharted territory for me, and I lack knowledge. This is my first 1/5 scale and I am seeking information so I can make an education based decision.
Weve all giving you our opinions, same rules apply to smaller scale electronics. I'd be going max 5 and the 1100kv set up and gearing the rig to keep temps good, along with cooling fans and or a good heat sink set up
Thanks everyone for the input. I have decided to keep the spektrum motor for now and change out the esc for a max/5 or the xlx2. That way I can see the differences first hand and use the stock setup as a baseline. I honestly enjoy the setups and tinkering more than I do the driving.
Not a bad move. Saw you were asking this question over on the Arrma forum. They are knowledgeable over there .
