- Nj
Stick with a high voltage servo and 2s. Well you would have to replace the throttle too as everything needs to work on high volts
Aight screw it thats what I'll do. I'll have to check in about the servo issue?? I'm guessing thats why I don't see any Bajas using them.Stick with a high voltage servo and 2s. Well you would have to replace the throttle too as everything needs to work on high volts
I'm right behind you. Well a little ways behind you anyway. I'm waiting for the symmetrical steering upgrade to be back in stock and then I'll also be looking for a compatible steering servo.So I've been looking at the Hilantronics 5000 as a steering servo for a long time because of its turning speed and good torque and I'm contemplating on pulling the trigger in 2 weeks. OR should I just bite the bullet for the 80kg?
Right now I have a SPT Servo SPT70HV-320 in and it has ok torque and all but it's just not all that good overall and it doesn't center well. I've noticed my Baja listing to the left and right after turning on gravel and its pretty annoying since my steering setup has no slop.
I'm thinking about the Savox SC-1256TG as a throttle servo however I just learned about the Futaba S9157 and I hear it might be better. Right now I have a ds-seevo because its what I had lying around.
This would mean I would need to upgrade to a Life battery. I'll take suggestions for that one.
I bought one on ebay. Its a little more expensive but it came within a week.I'm right behind you. Well a little ways behind you anyway. I'm waiting for the symmetrical steering upgrade to be back in stock and then I'll also be looking for a compatible steering servo.
I understand your all about the diy but sometimes its best to just buy the right parts.I bought one on ebay. Its a little more expensive but it came within a week.
Still new. I'm gonna build a battery and radio box using a plastic junction box and wire up external power switches and stuff... my radio has telemetry so I don't need a beeper.
Hmm.. didn't even occur to me to look on ebay. I'm tapped out at the moment anyway though, but I'll probably go that route too if they don't have them back in stock here in a few weeks. I'll be interested to see what you mean with your radio box and whatnot. I know I can't really hear my killer rc buzzer very well the way I've got it situated inside my receiver box. Good luck with all that.I bought one on ebay. Its a little more expensive but it came within a week.
Devils lettuceDabble with the devil eh troop?
