John Parks
Print my own
Yes you do doug
the Bartolone pipe is melting my pull start handle.
I want this https://www.davesmotors.com/IRP-Universal-Pull-Start-Extension-Kit but I think small aluminum piece would be better
Hahahaha I found a length of that yesterday and couldn’t remember for the life of me what is for. Cheers Doug now I remember.An inch or two of radiator hose and ya golden....had the same issue with my losi added the hose and problem solved
genius that would work perfectAn inch or two of radiator hose and ya golden....had the same issue with my losi added the hose and problem solved
thanks I understand what a radiator hose cut at an angle looks likeCut the end of the pipe at an angle so it stands sort of straight up
I have pics if ya want
No magnificent beards there todayYea Ryan is coming
Idk you may have been there and I didn’t knowSomeone hasn't learned to be self sufficient yet has he? I take everything I think I will need, plus extra. Tools, spares and fluids. Last Sunday for example could of been end of play because of a clutch spring, went in my clutch spares box and was up and running in less that 20 mins.
Junkie take everything you can within reason, don't rely on someone else having it.
Start another thread for you incessant babble about who where and when. This is Bob's threads.....No magnificent beards there today
Just ordered the front and center lsd’s and bought a rebuild kit for the mod clutch because it seems like the clutch is engaged even at idle
Just fyi a mod clutch rebuild costs $75
Seems like a couple of the springs gave up. The pads are still good but figured I would replace them while I’m in thereClutch didn't past long
