D⭐ XR5 ULTIMATE
Ok so thought I was having heat soak on my carb🤔 bulb was empty and sounding lean. So after a few hours the bulb still dose not fill after plunging 🤔 took the filter off carb not lose......put a rachet on it and snugged it up.....no joy🤦‍♂️ pulled off the bulb and check out the diaphragm....no rips or holes put it all back still not filling up after plunging 🤷‍♂️ so also checked to make sure the hoses where the right way round........carb kit or new carb
bibbity bob on doug (y),
small teething issues but you will soon have those sussed out,
is the shift point adjustable ? seems to be holding first gear for a a tad too long,
or is that just cos of the carb leak issue?
Int this mcd explains how the X2 works and how to adjust for your preferred shift👍🏻 so ill be playing round with it next👏🏻
