- Nj
you can add a puse line externally if you need to.@HXRC good question, i believe @TODD Mentioned glow plugs for lightening the rig but to be honest I don't think these engines would survive anything higher than what we normally see.
Interesting read on the carb stacking, would be interesting to see if it would work. One thing I didn't see is the pulse port would need to be shared for both carbs and I would think you would need to drill straight through the rear carb to link the pulse port,not sure if that's possible yet.
Max rpm do not know 100% on, but we have customers at times running 22,000 to 22,500 rpm. Normal range for us is usually 18,500 up to 20, 000 rpm constant. Keep in mind though this is using the two piece Zenoah ignition setup. Cars with one piece I can not give answer on it. Sorry.Not trying to de-rail, but what's the RPM limit for these ignition systems? I'd think you could pull more RPMs from a glow plug.
On topic:
How about stacking carbs?
