Online help is the hardest to assist with but i am having trouble with the assembly of my Drivetrain/Trans. As with most everything today there are no instructions included but the picture is what is included in the conversion. The movement from side to side is obviously not correct as there has to be something missing or i assembled it incorrectly.
Q: I am not sure where the fender washer (12mm ID) goes to be honest. When i line up the Spur and Pinion there is the amount of space that is the thickness of the washer from the Gear Plate to the backside of the Spur. Does it goes there? If so, the layshaft has about 5mm sticking past the Spur gear holder thing. From the picture of what is included there was No spacer so is this something i need to get separately?
Q2: There were (2) Shims in the bag that had the Clutch bell. The ID is to small for the shaft so what are these for?
Please advise as to what i might be missing.
Taylor RC Vesla Billet 3PC HD Transmission Housing
Kraken RC Vesla Big Bore Hardened Gear Set For Gas-Electric (Diff-Drive) **
Taylor RC Vesla Upgraded HD Billet Idler Gear
Kraken Vesla Blackbone Gearing Conversion Kit - Includes: Custom Vesla 54mm Blackbone Clutch bell - Set of Blackbone Gears (Pinion and Spur 20/55) - Billet Spur Gear Carrier - Blackbone Vesla Layshaft
Kraken RC Hardened Steel Bevel Gears Set for Vekta.5/Vesla.5
Kraken RC VESLA.5 HD T6061 Billet Aluminum Gear Plate
Taylor RC Vesla Billet LH Engine Brace
OBR 34 Reed
MOD 54mm Clutch
OBR 34 Reed
MOD 54mm Clutch
