dwarfy
- Rossendale
If you get a chance to put the ebee gebees up someone you've got to take it. , anyway he'd do it me if he had the chance.
Its funnier when you 2 do it tho You like a comedy double act
Which comedy act ?? :clap:
Cannon and Ball
Laurel and Hardy
Morecome And Wise
Ant and Dec
Bob and Spit the dog
Sooty and Sweep
Rod Hull and Emu
can you lot think of anymore. :lol::lol::lol:
Here is my KM 29cc alloy version VM, had it a couple of months now and too bought it from RCmodelz.
When you get it i'd advise you check every nut and bolt as they do come with a few loose, i've not had any probs so far, well none with the car its self, just snapped the screw that holds the servo horn onto the steering servo , mustn't have checked that 1. I've had about 3 tanks through it now and it's starting to loosen up and getting some good accelaration. :scooter::devil::scooter:
It does come with a Fail Safe too which is fitted to the 2.4 controller so no need to buy another, if you're going to fit a Kill Switch make sure its compatible as Voo2doo had 1 on his and it failed big time and ending up trying to meet the front end up with the back of the new KM.
http://www.youtube.com/watch?v=eN54CAggd6M
He just fitted new steel gears, but unknown to him 1 of the e-clips came off resulting in that gear sliding forward and slipping which chewed up all the other3 gears with it. £70 down the drain.:crying:What was up with the fs truggy then, that was lagging a bit
Looks sweet mate...........understood on the nut and bolt thing, I've had a few nitros so not a complete noob..........whats the score with running these things in then...........any recommended needle settings.........hope there not as much a pain in the arse as a nitro to run in!!
For me its got to be Laurel and Hardy lol,
they always gave each other the blame.
The FS is just not tuned Lee,it has a 29cc mill as well.
J.
Cannon and Ball
Laurel and Hardy
Morecome And Wise
Ant and Dec
Sooty and Sweep
Rod Hull and Emu
Hi James
29cc mm well get that thing sorted,its not doing the car any good now is it, release the beast :lol:
I thought you were ordering the KM but with 29cc upgrade?? The HPI only has a 23cc engine in it. They rev a tad higher than a bigger engine so good top end. A decent pipe will bring it alive. GET THE PLASTIC OUT & GET 1 ORDERED :santa::clap::happybday::cup-1::celebrate:
If only I can hide the visa bill mg: Yes I do have that truck in my sights,just don't know what to pull the trigger on. the Km does have a big bore kit avail for 59.00 difference.How hard of a task is this to do? So with the big bore kit should change the 23cc to 29cc (right)
I will do this:::: :w00t:
