3 shoe adjustable clutch ??
I been looking for something like that , looks like you have 3 screws U have to adjust ??? it just as easy to change out you clutch with different springs ??
i like the idea of it, but after doing a bit of reading the way i understand it is that #45 steel is a structural steel that needs specific heat treatment,
its a mid carbon content steel thats on the cheaper end of the price scale,
what springs to mind for me is that any clutch with a steel on steel friction, clutch shoe to bell i mean , should really be sintered so that the more its used the more of the sinter material is tranfered to the bell giving more grip,
plus consider the weight of the clutch, its gonna be a heavier clutch than most, which means more rotating mass which in turn means more effort from the engine to spin everything up,
its like having a heavier flywheel but on the clutch side,
just my thoughts thats all (y)
If you drill a hole in the clutch bell you could access the screws without disassembly !! Hummmmmm ? would you need 3 holes to keep it balanced ?
Not that I'm aware of, and you so far out if any power range that low in these little things it's almost not worth it.
testing 1-2-3 I want to see where the torque is so test at 4-6-8-9.5k rpm right ??? or get that adjustable clutch and do the same thing.
Im talking to Trevor about getting one ASAP to try out.
