This truck is the v2 version. The trans and diff are all one solid case. I have both versions.It's based on a losi 5ive t platform not the baja 5t or 5b. The engine has inserts to set the gear mesh. I tossed them, use washers and set mesh like normal. Gear options should be readily available and cross most of the losi 1/5 scale platforms.
Yes that is what is on it. The boys and I ran some yesterday and came to the same conclusion that I would have to revert back to that.Is this the garbage thats on your truck?
https://www.kingmotorrc.com/product-tdn59018
If so your stuck with stock gears unless you get the factory 5ive t 2.0 style trans.
https://www.ddmracing.com/Modified-RC-Center-Diff-Mount-Set-for-Losi-5ive-CDM
Should be like this
Agreed......not hard at all..... like some I like the looks of the sealed gear box. So with that said the looks don't make up for handling....out with the new and in with the old.I'm not understanding what's so hard about converting over to the 5ive t open setup. Your not bound to the sealed gearbox. You need the clutch carrier,center diff and gears
