gavsta72
Yeah but that's no good when the car's run offDidn't last long at all. And you know, theres a off-button on the fan cover the pulll start.
I'm not saying completely ditch a kill switch all together. I'm saying remove/disconnect whatever to rule out if that's your problem. If it is, then get a new ks, if not, put it back onYeah but that's no good when the car's run off
Lol thanks Sean ?Z may be a young pup but his advice was solid.
Yip I have heard about loads of glitching coming from them ? disconnect it and see ??The kill switch in question is the Dynamite optical kill switch
Hear hear??If it's too hard to pull I would check the ignition coil rubbing flywheel, remove your spark plug and if it's still pulls hard check ignition coil fly wheel
