If you are looking for more bottom end or top end speed you can lookwell im going to start the thread as i cant wait anymore and i have confirmation that my boat is no longer an order ticket and it is now a hull waiting to be rigged.
the boat is black gel coat with all purple hardware and every bit of aluminum on the engine is purple including the engine mounts.
the mods are
BZx4 mod which consists of a championship ported head, high rev piston and base is cut for more compression- adds 10 to 15 mph...should put me in the high 50mph range hopefully close to 60mph
sharpened and balanced beryllium and bronze 2 blade prop
tuned race exhaust
window frame and stainless mesh for the canopy instead of vinyl decals for windows
billet fuel door so the canopy doesn't have to come off to refuel
added a tachometer
very cool purple cooling head with 2 in 2 out fittings
2 in 2 out purple exhaust manifold
purple outdrive and rudder
billet purple water pump cover
billet purple gas cap
2 billet purple exhaust tips
billet purple bonzi clutch system
my mods to add
zen 30.5 pum engine
purple water lines
lime green fuel line
lime green taylor spark plug wire with msd plug boot/ i have to make myself
billet carb diaphragm cover
bartolone v2 velocity stack
DDM billet pull handle
FS steel clutch
Picture for reference mines just blackView attachment 74643
If your looking for a quicker bottom end or top end speed you can look at the 5 blade props or 2 blade for the best bottom end out of the hole preference.well im going to start the thread as i cant wait anymore and i have confirmation that my boat is no longer an order ticket and it is now a hull waiting to be rigged.
the mods are
tuned race exhaust
added a tachometer
my mods to add
zen 30.5 pum engine
purple water lines
FS steel clutch
That's why you need a 1:1 boat for retrievalOk so on the big day of her maiden voyage don't launch your boat like this please
