I used button heads on the clutch side motor mounts and used the stock 19 tooth spacers on the back 2 motor mounts for now until Demon can get me the correct spacers for the front.
I am a bit confused. If you used the stock 19t chassis inserts on the back 2 motor mounts, then the engine should be straight and it should be possible to use same inserts on the front, or am i missing something here????
Did you have to modifie the inserts?
