- Crafers South Australia
My bad did not see the wing .......You mean this part that blends in right now . Damn wing is 14inches wide . How did you miss it ?
Looks good with a shot of the back
How long did it take to get engine after you ordered it? I want to get one for mtxl.
Hate when u pinch urself with pliers ?Small update for today . Safety wired all the body clips to the cage today . It took about an hour and a half . Stuck my fingers 3 or 4 times with the end of the wires and closed the safety wire pliers on my left index finger once. So the 2 stroke Gods got their blood sacrifice today so they should be happy. Damn I hate doing safety wire but if it keeps me from losing body clips good.
Next step is to start removing parts so that I can install the Reed Case . More pictures to come.
?? Never seen those B4, but I have pinched my finger on cutters and it's really fun ??Yeah I don't know if you've ever used or seen Safety wire pliers but thet have a built in cutter for cutting off the extra wire . That was the part I caught the side of my finger in . I should have kept on squeezing for a second longer . Then it would have just taken a chunk out of my finger instead of 2 cuts for the price of one.
Mate of mine is a truck mac ......he was carrying a head to a work surface (cast iron head) as he was putting it down on the bench ( crotch was the same hight as the bench) pinched the tip of his member oooooooooffffffff!!!!!!
Ouch!
Ouch!
Ouch!!!Ohhhhh . Ok that's worse than getting caught in the zipper of your jeans , which really hurts.
Ouch!!!
That would hurt
I got a 2 year old to the balls a few months ago..... thought the vasectomy was painfull????????????????cried for about an hour and my daughter and wife never stopped laughing the whole time.....
That would hurt! I try to avoid foriengh objects near my nuts, the last time was I was kicked in the nuts hard 9-10 yrs ago from then I've been very careful lolYeah the Zipper episode wasn't as bad as the accident I had practicing with nunchucks . That's a mistake you only have once . Thank god that was 40 years ago.
Looks awesome! ? That new bartolone stack is sickIt's starting to look like a mean little Braapppper . Mounted the Expansion chamber head pipe( with head studs lock washers and drilled nuts for safety wiring), The Carb (WB1107) ,Bartolone Velocity stack and DT1 filter and outerwear to go with it .
