It's 6 of 1 - half a dozen of the other. If you run on dirt or sand, you need an enclosed clutch. Clutch slip is the cause of heat build up. In 16 years, I'm on my second clutch. And it's a 49 mph Baja. I use red springs and proper clutch material. I dislike metal on metal clutch setups - it's a recipe for clutch heat and constantly slipping.Not too keen on them enclosed clutch bell holders , no cooling on the clutch, and the brake mount is not needed with disk brakes fitted.
Check each wheel at the rear for binding , but I bet it is the spur shaft binding up , that purple spacer in the above picture is the one I had to thin when fitting the Blackbone spur system , or it could be because I used a Taylor Titanium shaft.
If not that , then remove calliper off one side and see if it is dragging (which I doubt).
Metal clutch from Taylor is bomb proof.
It's a great setup you have with yours - I like the spur holder and the lighter spur. Don't get me wrong - I think the hydraulic discs are very cool, but on mine, given how effective and consistent my rear brakes already are, I'd only be looking to supplement them, rather than replace them.You pays your money and makes your choice !
But in this case , the disks are fitted ,so standard brake is a moot point .
I removed the standard disk and pads from mine when I fitted the hydraulic brakes, as I did not want any undue binding.
Taylor fit and sell metal clutches for their engines , as well as fully open vented clutch holders , so I will go with their experience .
Sand in the clutch is unlikely to be a problem as far as I am concerned , as we are in the UK .
Take the clutch apart and inspect the shoes and the bell. The shoes shouldn't look shiny. If they do look glazed, provided there's a decent amount of friction material left, you could try sanding them. Otherwise, they're cheap enough to replace.Had a few runs with the car now, some issues:
Clutch is deffo on the way out - new one on order.
Box exhaust, while quiet, seems to be robbing power - never seems to get into the band.
Front FID brakes seems to have too much drag, like the pads are not retracting - any ideas?
Alloy wheels are pretty heavy. Best stick to nylon beadlock wheels.Can anyone recommend a set of replacement wheels - i have standard size tyres - are the alloy wheels any good?
Just got an Olimat Silenced exhaust, so that will be going on this weekend.
