I don't think you "bash gently" lolOk.pics incoming
Totally forgot about this...jus sorting pics now as thete were on photo bucket still@evssv.... I smell a pile of ?
I do....I don't think you "bash gently" lol
Yes...and yes.....about 7-8 i thk it was...full end over end ones aswell at wotMan that looks like a hard land followed by a cart wheel ?????
Yeah but it's double that kraken, I'll just get the kraken as much as I want the rcmax I don't see the needRcmax just came out with a titanium baja lay shaft. I'd recomend that
Oooo the tr gearbox looks the shiteTotally forgot about this...jus sorting pics now as thete were on photo bucket still
After that i went tr quik diff
I do....
I run a pcs slipper thing in mineRcmax just came out with a titanium baja lay shaft. I'd recomend that
Ur obv not going hard enuff then.........I guess im just lucky or something. I have had the same KM alloy diff in my baja for 3 years of hard bashing. Just took everything apart to install the FLM drive cups and shafts and all of the insides look perfect. No worn drive gears, no wear on the bevel gears and the bearings feel smooth as silk. Only thing it need is some fresh diff fluid?
My bevel gears are fekd maybe b cuz the extremely thin fluid ? Like alittke thicker than watterI guess im just lucky or something. I have had the same KM alloy diff in my baja for 3 years of hard bashing. Just took everything apart to install the FLM drive cups and shafts and all of the insides look perfect. No worn drive gears, no wear on the bevel gears and the bearings feel smooth as silk. Only thing it need is some fresh diff fluid?
What do u mean? That my oil is super thin?That don't sound right....
You will need much thicker diff oil than that Zee, I have 1000000cst in my bigbore diffWhat do u mean? That my oil is super thin?
Yup i know, put 500k in it, think I should go thicker? My oil was like 1000cst B4 I put 500k It. Think the 1000cst was too thin and didn't protect the gearsYou will need much thicker diff oil than that Zee, I have 1000000cst in my bigbore diff
https://www.modelsport.co.uk/index....oGXuCKZGHySLXXMQUOBkSItlrzSF-RuUaAiuJEALw_wcB
If you go too low your rig will diff out an you can say bye to your tyre, that 71 will destroy wheels for fun?Yup i know, put 500k in it, think I should go thicker? My oil was like 1000cst B4 I put 500k It. Think the 1000cst was too thin and didn't protect the gears
You run a bigbore engine?Im only using 5000cst in mine
LOL. I'm Gunna need Brps, tho there pricey as hell!If you go too low your rig will diff out an you can say bye to your tyre, that 71 will destroy wheels for fun?
Lol..my mate Arron(bebop rc) blew quite a few brps up with his 71?LOL. I'm Gunna need Brps, tho there pricey as hell!
I think I might play it safe and go for 1mill, not a fan of popped tires.
