moron these problems happen to every rig.I know what your idling issues is, I’ll try to explain it as simple as possible so you can understand and fix the issue....:
BAJA
SELL IT
BUY A 5iveT
= PROBLEM SOLVED ??
GOOD LUCK ???
BAJA
SELL IT
BUY A 5iveT
= PROBLEM SOLVED ??
GOOD LUCK ???
just needs to be tuned a lil bit. but the plug did the trick right?so i changed the plug and put fresh fuel.... and now there is alot of smoke from the pipe.
np, remember, if you have strange issues like this again , first change the plug , then go dive deeper if the issue persists.PLUG DID THE TRICK!!! thanks for all you guys's help.
