I have the 80cc.You have the 80 or the 50gt?
It’s normal some servos do it some don’tI noticed yesterday while cleaning up that my brake servo did not rotate while pushing on the horn. I don't believe they are suppose to feel like this as any other 5th scale servo i have will move fairly easily with some force.
I have a Raminator also with a RC MAX 50 GT. I had the same problem with them Servos. They don't come calibrate out the box and they fight with each other and burn out very fast. I went threw 5 in a week. I ended up driving to the Primal rc store and they gave me the upgraded Servos and said plug them up first so the motors can calibrate, then attach the horn so they can be aligned. Also Blue Loctite every screw on the truck cause they will all rattle lose with any upgraded engine. I found myself replacing 1 or 2 screws everytime I drove it.I have the 80cc.
That engine ain't no joke. You will need a Wheelie bar for it, I'm telling you from my mistake, I hit the throttle and the truck did a back flip on me and smashed the roll cage on the pipe dented it. I had to bend it back. Also it's good to get the exhaust silencer they sell for the rc max raminator engine from DETROIT PERFORMANCE, cause it's going to be so loud where you can't hear and will need ear plugs. Just trying advice from what I went threw. ONE more Important thing they don't tell you is, you will WANT TO ZIP TIE THE SCREW THAT CONNECTS YOUR DRIVE SHAFT AFTER YOU LOCTITE IT. I lost that SCREW 4 TIMES AND IT WONT DRIVE WITHOUT IT. JUST TRYING TO PREVENT THE HEADACHES I WAS HAVING. The Raminator get so much attention everywhere you go. Its a Beast..Got the motor installed just now.
