Can't figure out how to bind Futaba radio
Do you have any tips on how to route the power switch wiring back through the holes to both the receiver and battery box?
I don't know if have wire extensions i just need to get the plugs back through the holes so i can tighten back up the throttle servo
the only part im having problems with is that actual pipe mounting to that bolt coming out from under the carb
I just ordered new servos but i got a hitec HS-5645MG it looks to be too small did I maybe order the wrong one
