Speeddemon49201
- Reaction score
- 17
- Thread starter
- #21
Sean won!!! Diaphragm hard as a rock. Gonna be sending it tomorrow!!!!!
Dark majic!!!! Is all I can figureOi sean whats up with the spiral diaphragm...seen it and you've mentioned it before can you elaborate
I'll post you one.I use a non ethanol gas so I may be ok
I got some amzoil dominator and 89 rec fuel. So not ethanol here either.I'll post you one.
I'll have to pick some up. It was ethanol free so I figured it was at least as good as 91 ethanol pump gas. I could be wrong I'm no scientist.Thanks sean.. ill return and send those body clip leads to you.. I just been a lazy fek I actually just walked into the rc room today..been about 2 months since I looked at the 5ive ?.... @Speeddemon49201 best be running 91 or better in yer rig
Just got mine down off the shelf the other day. Getting itchy to run it.Thanks sean.. ill return and send those body clip leads to you.. I just been a lazy fek I actually just walked into the rc room today..been about 2 months since I looked at the 5ive ?.... @Speeddemon49201 best be running 91 or better in yer rig
Octane is octane alchohol fuels have a higher rating the straight gas, plus burn cooler. You just need more of it to make the same power, down side is its hydroscopic. I have too many 2 strokes to play the expensive fuel game. Run a good fuel stabilizer and you'll be fine.I'll have to pick some up. It was ethanol free so I figured it was at least as good as 91 ethanol pump gas. I could be wrong I'm no scientist.
You can get by with 89, high test is preferable.Sean can correct me if im wrong but I believe 91 or higher was required in these rigs
I run 91 here has no ethanol in it??Sean can correct me if im wrong but I believe 91 or higher was required in these rigs
