I wanna know what the car looks like. Those vekta are fecking heavy
Ahh yes. Similar situation when my connector became unplugged from the receiver. Luckily i was not going full speed when i lost control and it coast to stop. Dodging the trees the whole time. I was watching it like no don't hit it don't hit it.They all have killswitches bro. This is the on/off switch. It physically shut off, I was at full throttle when it did, so it had all that momentum still. And as you know, if you shut your rig off you have zero power or control.
@Seandonato73 you have a drawing of what your talking about?
Bad drawling, but I think you'll get it.
I was going to suggest this, but they normally just ground out the coils, not really helpful in this application. I had thought about mentioning them then went and played with one I have here, makes the connection once the "key" is pulled out. So it's a normally closed switch and the "key" holds the switch open. Dunno if they can be had the other way around.I have wired in a dirtbike tethered kill in place of a key, I am sure you can use as a switch and find a nice one...
https://www.mpsracing.com/products/MPS/hc01.asp
Need to add that to my wishlist also need several of those antenna mountsDdm has them and now I know what they are for
Just picked up a few off evilbay for $11.00 each.Need to add that to my wishlist also need several of those antenna mounts
That’s a price I likeJust picked up a few off evilbay for $11.00 each.
