Crucial 5ive-T
No problems. I also think from reading the manual the lights need set on ps2, not ps1. Something about ps1 is a momentary switch, and ps2 can be set to on/off. For some reason I think we delt with this with @Basher5iveT420 a few years ago.
Yeah sw2 is the momentary switch. I use it for my killswitch
Pololu is my go to and they make an awesome bec .The one I am using bumps the voltage up from 7.4 to 20v and works awesome for my lightbar.
I will look into these. Thanks??
Finished up some Ledos pizza then I finished everything but the light bar now. Set all wheel camber to neg 2deg. Not a fan of the extended rear adapters so I will be ordering a set of the regular adapters. Guess I'll use the ext adapter on the baja??‍♂️
ur memory is on point Sean, this was a long time ago ???
I went thru a similar issue when I installed the lights on my rig.... I literally spent hours trying to figure out the right setting on my Futaba 4Pv ....nothing worked...
turns out you need a light controller switch ??
the Killer Rc v3 is the coolest one on the market IMO ???
View attachment 62468View attachment 62469View attachment 62470View attachment 62471
Keep the extenders on for a run. They might do a world of good for performance. I’ve seen a guy cut out his rear fenders like thisBB99304C-4471-4B28-A3C6-652ECD5D5F80.webp
it looks a ton more aggressive and gets rid of the wheels from poking out soo much
My wife says my mind is like a steel trap, just full of useless information and nothing overly important. I could remember all that stuff about the 4pv, but forgot about our anniversary at the beginning of the month ?
