- Reaction score
- 27,691
- Thread starter
- #181
OOOO nice ?Same to you buddy ! I'll do my best with this one... just got a bit of a raise for the new year ?
FS 54mm clutch when it has the small carb on and makes "low" 12-13hp for the time being then will go RCMAX 62mm or ALX 70mm systemHey Zee, what clutch you gonna be using on this build bud?
Yup ?? my crankcase is the older version and will only accept the 70mm, wish I could go 80mmCool? Alx 80mm clutch is the daddy now
Hes as patient as they get when I needed a new engine parts that were hard to locate or if I had to wait for postage from across the world I got another whole engineI know you determined to get your crank to work but I would have caved In an bought the bzm 39.6 gold crank and had done with it, obvs I'm not a patient as you[emoji23]
Can't get rods and rod bearings for those cranks anymore and that size you really cant find ?I know you determined to get your crank to work but I would have caved In an bought the bzm 39.6 gold crank and had done with it, obvs I'm not a patient as you?
Rods an bearings as in gidgeon pin and needle bearing?Can't get rods and rod bearings for those cranks anymore and that size you really cant find ?
Can't get the con rod, you can't get the big end needle bearing or the small end needle bearingRods an bearings as in gidgeon pin and needle bearing?
I cannot use that crank because it has a 10mm grudgeon pin so it won't fit the Piston on top of that I don't have 250, also is that in euro? If so that's even more in USD. But he does have a great deal for it.View attachment 48505
Alx offered me the right crank for €250 shipped the other day an that comes with the needle bearing, the gidgeon pin comes with the head kit.
I honestly don't understand why you are struggling mate as the case is designed around off the shelf parts.?
I cannot use that crank because it has a 10mm grudgeon pin on top of that I don't have 250, also is that in euro? If so that's even more in USD. But he does have a great deal for it.
ATHENA HPR, cuz it was cheaper than the MalossiWhat head kit do you have?
Hmmmm? I have a Athena 50cc kit here that i took off my engine to fit the mallossi kit that was a straight swop apart grom resetting the squish, i also have a stage6 50cc kit that fits tooATHENA HPR, cuz it was cheaper than the Malossi
Unfortunately mate if you want to hang with the big boys you need to dig deep, very deep ???ATHENA HPR, cuz it was cheaper than the Malossi
Also 250 Euro in USD is $286,
How is it? Like power and reliablity wise. Haven't found really anything on any Athena kit. Ill see about maybe just maybe I can swap my piston and get the crank. But don't count on it. ? Hopefully I can make it happenHmmmm? I have a Athena 50cc kit here that i took off my engine to fit the mallossi kit that was a straight swop apart grom resetting the squish, i also have a stage6 50cc kit that fits too
Ran well with the Athena kit on, plenty of power and over 17k rpm.How is it? Like power and reliablity wise. Haven't found really anything on any Athena kit. Ill see about maybe just maybe I can swap my piston and get the crank. But don't count on it. ? Hopefully I can make it happen
?? Expensive as hell tho. The Mhr replica is like 260 USD and the MHR team or whatever it's called is like 340 or somethingRan well with the Athena kit on, plenty of power and over 17k rpm. Soon as the mallossi kit came along I just jumped on it because it was the new best thing?
