Just a crazy thought, but does anyone think the stock tires are too soft? Soft enough to act like an under inflated tire on a real car?
I completely agree. Under hard cornering you can see the stock tires' sidewall folding over so bad it looks like you have a flat tire. I actually replaced mine with stock 5ive-T tires with the original DBXL foam (which I don't like either) and it seems to make a noticeable difference in feel, but I haven't driven it yet since I moved to nights at work. I am going to order a set of Pro-Line Trenchers when they come available. http://www.davesmotors.com/pn1154-13.html
I need to rebuild the shocks as well. There is almost no rebound and it bottoms out when dropped from a couple feet, or driving off of a curb. I actually bought the car used on eBay, but the previous owner only ran about 1/2 tank through it on pavement. It was in new condition when I received it. He said he rebuilt the shocks per Hemistorm specs (see Hemistorm DBXL on YouTube), but they just don't feel right. I'm thinking about ordering these:
https://www.largescalerc.com/1364-StifferSpringsforFrontorRear1Pair-LosiDBXLByPro-SpecR.aspx, but don't know what weight oil would work well with them. I don't even know the stock weights.
I am learning a lot reading all your comments. I've never taken into account diff fluid weight before. I think I will rebuild those as well per some of your recommendations.
I love the DBXL, it just needs fine tuned. I'm thinking a lightened flywheel and 8k rpm clutch. Any thoughts on those? I do have a DDM 29cc Big Bore kit that has not been installed yet. As of right now I have it running side-by side with my friend's 5ive-T, but I need a little more bottom end. I also need a different steering servo. It takes about triple the distance for left turns than it does right turns. The servo doesn't have the same distance of travel in both directions.
