Off the engine. Found the problem. The bearing had pulled out. Took it out and 1 of the bearings are bad. These are some big ass bearings. I hope a bicycle shop has these. Most likely will buy a pair of shielded ones.
Same here that's why I'm curious if it's normal or not after seeing it asked.All.pf mine have a bit of side to side play. Tbh I never worried about it.
+1?All.pf mine have a bit of side to side play. Tbh I never worried about it.
Quick fix? called the bin ????New bearings installed. It does have about maybe 0.5mm play but that's normal for heat expansion.
Now to fix the damn leaking ddm manifold.
