Doug's hpi 5B SS
finally i finished the install with ht FLM extended arm kit
51834
the pins you get with kit only just fit in the slots in the drive cups:unsure: had to tap them in
51836
greased all the bits with some lithium grease(y)
51835
landed up turning the ball over in the upper arm end...... they were too high when i put the wheel bealocks touched
51837
put new sway bars front and back(y)
51846
51838
rear shock tower brace
51839
beedlocks touching the rod ends
51840
switch around gives a few mils clearance
51841
Doug you be getting it in brah. You spare no expense?? Looks good.
My theory is this if you gonna do it ?......do it right?? still have some more stuff I wanna get
Glad you used a good lube there. There's a lot of wear and tear when it's dry.
Yip having shaft in a dry cup is bad news ? so lube up boyz?????????
