How bad you want me to RIP your arse up for that statement Z ?
I'm good thank you ? last time I reused gaskets ,it leaked like a motherfeker ? my opinion of course.How bad you want me to RIP your arse up for that statement Z ?
I would reuse
I'm torn as I feel they look good ........but I have fresh and iv put tones of time into this? ah fek it I'm gonna slap new ones??Fek, use them. They look ok. If your feeling scared give me a dab of glue and run them.
Might as well do it right the first time ?
I win this time Sean?????I'm torn as I feel they look good ........but I have fresh and iv put tones of time into this? ah fek it I'm gonna slap new ones??
Hey , shut it MR No 70cc ? least I gave it a go ?Mr do it right, 70cc from scratch ??. Post them to me doug, so I can use them over again. ?
Just because we can try things, doesn't mean we should. Take putting diks in your mouth ?? probably seems fun to you, but you really shouldn't???Hey , shut it MR No 70cc ? least I gave it a go ?
Wrong, if you haven't tried it, you can't say it isn't good ?? I like it, cuz I've tried it with me own cok ?Just because we can try things, doesn't mean we should. Take putting diks in your mouth ?? probably seems fun to you, but you really shouldn't???
It seems like the rc GODS ??? are testing my grit every step of the way?
Check this out?
In the pic are the original crank (rmck)
And the one that was sent straight from Korea ? now here is the the thing??
The small end of the con rod is not the same size ? View attachment 59043View attachment 59042
WTF ?? In the small end there is a roller bearing and X2 retainer washers that go on the inside of the piston.....like so ??View attachment 59044View attachment 59045
So when I put it all together and put on the piston it's such a tight fit ? ......so iv done this to one side now onto the next one ??View attachment 59046
Iv sanded to two washers with oiled 600 grit paper to get it all to fit with enough movement for it to work properly ????
Do it do it do it do it ??? I'm gonna be dissatisfied if I don't see a startup by 4am my time , that's 3 hours and 10 mins ????Now now boyz??
Iv been busy? check it out got most of it done basically I can slap it back in the
Chassis ???View attachment 59070View attachment 59071View attachment 59072
Starter ,coils ,mounting bracket, 1107 carbs new gaskets all round billet intakes?????
What time is it there?Mmmm I don't think I'll power through ?started on the rum and coke bout an hour back? iv made good so far ?? don't want to rush and fek it sideways ?????
That's 3:30 pm? Pffffftttt, you can do it15:30?
There we go, that's the spirit, finish that biotch!Mmmm ok ?? motor is in the chassis ,top plate , black bone gears?View attachment 59073View attachment 59074
Keep you lot happy for 5 mins????
Yeah but, there's still day light ?Tomorrow is another day??
