Dashz
- Spain Andalucia
Hi there. I have noticed that when the engine is hot (after 10-15 mins running and being ripping full throttle) if I drop the throttle to idle at any point the engine dies instantly.
When it bogs down it feels and sounds like the idle screw is set lower or the engine is running rich.
The idle screw is not the issue (it doesn’t move a hair, also, letting the car rest for a couple of minutes makes it idle nicely again)
I thought that it might have to do with running a very rich high speed needle but Im now using stock settings… This doesn’t happen in my Baja, not even after running a full tank straight away and it uses the same Walbro 1191/1107 carb with same settings.
The engine in this rig is bigger though 36cc compared to the other 29cc.
