Finished TLR 5ive-B
Very nice
Looks like time to burn some fuel :)
been looking into doing custom body paint for my 5t 2.0, watching vid's,
but pricing slowing me down, have other upgrades higher on the list
Thanks. Working on break in now. I really like these servos and might upgrade my 2.0 also to them. Hitec D845WP
Awesome job! Which engine did you fit? And what kind of servos?
I used the zenoah g320 and use all three hitec d845wp.
Can see in this pic cutouts iv done
Got melt had to trim
View attachment 48656View attachment 48657
Your cuts look really clean. What did you use to cut the back by the starter. And what did you use for the rectangle shaped vents?
Also check out these schlock covers. I run them on my 5T and love them.
fegured out how to post (y)
I need me a bart.(y)..loads of servo horn clearance....o_O
last pic...is the exhaust exit facing the chassis:oops:
yes
thinking of putting a spacer under mout that should raise above and also change angle of exhaust pipe to add silicone tube
mount
need to proof read lol
That pipe is for the 5t, didn't calm to be for 2.0 thought it would be ok, and I do plan on a 34 reed full mod later so going to keep it
If I have to will weld a tube to tube to get it out side
Just looked at DDM site the
Hitec D-845WP 32-Bit, Multi Purpose, Waterproof, Steel Gear Servo w/Free DDM Alloy Horn DDM Deal of the Day for 1/5-6/19! Reg Price 104.99 - ht845
NOW thru 6/19 $87.99
wifey NOT going to be happy o_O
don't forget to use coupon code LSF
Brings the price down a few more bucks.
Here's my Victory pipe on my 5ive B and heat venting holes/mesh. Plenty of throttle/brake clearance.
yes
mount
that's not good imo..(n)..r barts this bad a fitting???my 5ive one fits sweet..(y)....whats this on btw??a 5 or 5b?
Yes i have a bart pipe on my 5b:love:(y) and it fits great
Had two issues the end was a bit short so i put radiator hose and clamp on the end. Getting the head pipe tight i had to mod an allenkey and cut the end off (y)1540650832340.webp1540193269331.webp
What did you use to cut your allen key?
