Gaffle
- Atlanta, GA
Excuse my newbie'isms but I'm excited that I started my Losi 5ive-T 2.0 for the first time. I let the engine idle for about 10 minutes, waited 20 minutes, then ran it again in my driveway for 10, waited then drove on the street for 5-10 minutes, all at nominal speeds. The buggy stopped but I think it was due to the transmitter failsafe or Killer Bee switch voltage failsafe... it was beeping as if it had lost the signal. Well anyway... I took my cover off the truck and noticed lots of fuel on the chassis, tank and a little on the stock air filter (w/ Outerwear). Is this normal? I have an aftermarket gas cap (DDM Racing alloy with a tiny hole on it).
Also, what does it mean if you're running, hard brake, then the engine stops? What adjustment needs to be made to prevent that? This only happened once and it was actually when I got the beeping failsafe noise. I'm charging all batteries now and may set the killswitch to 5v for receiver battery fail...
