Yep, my dbxl turns right at 110%. Just the way the cookie crumbles sometimes.What adjusting it past 100%?
Make sure to zero the trim before adjusting the sub trim. Then adjust the throttle return spring if needed.End points have been done, gonna give the sub trim a go over the weekend.
Looks like I’ll be ordering one of these, dunno when it will turn up with all this going onJust get an extension lead and solder it on your cord.
ah mate tell me about it I don’t know how I haven’t yet either ?Damn you're having a rough go with this rc. Id have probably raged out on it by now and threw it in front of a fast moving truck.
Hope everyone’s well in these times??. Got a lot of time at the moment so threw the new receiver switch in and nothing working at the moment. Wondering if theres a way to check if the receiver is fried, or the servos? Pulled the lid of the receiver and can’t see anything burned out. Also on the lipo charger it’s got a servo tester, and all are reading the same, although I don’t know what they should be reading. Appreciate any input as I don’t want to shell out on all electrics at the moment.
Yeah the receiver is a futaba r304sb so I’ll try and re bind it tomorrow fingers crossed all works
Never had that before having to re bind, but got the receiver going by passing switch. Started plugging in servos, steering d845 working ok. The d840 throttle don’t respond and makes the battery not disconnected as quick. Took the apart and found the short across the bottom of the wires in the servoAlso ,if your still not sure about the switch ,you should be able to bypass an plug the batt. directly to the rec.
to test it!
I had to re bind before from my stuff being disconnected & not being used for long periods of a time!
But anyway ,I hope you figure it out!...
