The losi rear shocks are a good bit shorter then the vektas. Im pretty sure I have pics of them side by side in my build thread
Man looks good nice idea on the wing decal never thought about thatThanks Sean. I wasn't sure. I must have missed the post, my bad ♂
Well wraps done! That wasn't too hard, but not too fun..patience.........heated and now going to let the glue cure overnight then I will cut the screw pockets and reinstall everything tomorrow.
Can't decide whether to cut up the wing decal and wrap the dominator wing or just throw it on the blade.
So making equivalent of the Baja rears but for the KV5TT.I have an idea, may need a haric specialty to make a sleeve. But when you cut a spring you actually increase its spring rate. So you could conceivably take another stock spring and cut it down to say an inch or so, and stick a guide sleeve in between that short spring and the stock length spring to make a duel rate spring.
You and @John Parks been talking?I have an idea, may need a haric specialty to make a sleeve. But when you cut a spring you actually increase its spring rate. So you could conceivably take another stock spring and cut it down to say an inch or so, and stick a guide sleeve in between that short spring and the stock length spring to make a duel rate spring.
I did think of this, I just haven't had time to measure up some cups.I have an idea, may need a haric specialty to make a sleeve. But when you cut a spring you actually increase its spring rate. So you could conceivably take another stock spring and cut it down to say an inch or so, and stick a guide sleeve in between that short spring and the stock length spring to make a duel rate spring.
Jon Hall at Joker designs.@PortCityRC
where did you get your wrap? That looks really nice.
Any interest brother? No rush, but I'll gladly make it worth your time$$$. I was looking around for ideas a couple months ago, also looked at the Raminators shocks as an idea. I tried getting shock therapy to make me custom shock sets a few months ago, gave them my specs, but said they couldn't make them. I have a local custom spring shop where was also thinking about if they could make a set of dual rate springs, but my best luck will be making cups and cutting springs. Also thinking ahead are you able to obtain Delrin material Hari and cut it on your CNC? It should be made out of this so it doesn't rip up the shock body and let's it slide properly and is very strongYou and @John Parks been talking?
My bag never tagged @HaricPlease keep me informed
Ram shocks for reference of their cup design
Holy fek 304lb load Too much on themDamn i forgot to measure that ...
The rears this might work. The od is 1.9" vs stock 1.6"
Spring-Tempered Steel Compression Spring, 6" Long, 1.938" OD, 1.438" ID
https://www.mcmaster.com/96485K141
Yeah i know haha but I am still going to try it.Holy fek 304lb load Too much on them
