Ok first your wrong, they have exhaust valves, or sliders to control the exhaust port size, along with the reeds, intake bypass valves, amd a waste gate. They also use direct injection, and boost injectors in the throttle body. Hell even the crank bearings are oiled like a 4 stroke. So yes I guess I was wrong that you turbo a 2 stroke, but I guess at the same time I was right as well. This engine was specifically made for the turbo. It's about as far away from a loop scavenged 2 stroke as you can possibly get. They solved the nagging low end torque and fuel consumption issues with the direct injection and (you guessed it) exhaust valves. (Funny did I mention that you needed valves ? Oh yeah I did) and to help that out they needed the waste gate to do 2 things, manage exhaust pressure to keep the air in the cylinder and to keep the turbo at its happy place at a maximum 4 psi (good lord were just making tons of power at that level of boost) the only benefit of this over complicated mouse trap is it retains power at altitude. Will it last ?
you got me, being a brand new engine and largely untested tech to make it a turbo engine idk. Time will tell that. But since were on the sled notion I will say there have been turbo kits for them and other 2 strokes for years, they all have a few things in common. High octane fuel is needed, fuel economy goes to the dogs, and they are unreliable at best. Found an over abundance of information about guys installing these "turbo kits" and sled engine meeting a short death, for various reasons. So in short no you cant turbo a 2 stroke. Well you can if your pockets are deep enough and you make it surprisingly like a 4 stroke, just with extra parts and twice the electronics to keep it in its happy place. Have fun with that in an rc car or whatever dinosaur of a 2 stroke you want to experiment with.
Cheers.
