Losi 5ive B Victory exhaust Issues, I need help!!!! Please come in
tman
Has anyone used this Victory pipe, It comes very close to my Throttle servo. It touches My Body. Any suggestions. Will it work?????
I'm not familiar with that pipe so I am about of options. Someone will chime in I'm sure
The body fits, but I'm afraid of it getting hot enuff to melt the body. Also not sure if it will get to hot and melt or damage the throttle servo arm. It sits about 3/8 of an inch from the arm. I have seen before other guys using this pipe. Not sure I like it.
my samba pipe was so close to the servo horn ☹i had to shave sum off the corner of the horn ?...
sayin that my Bart pipe is close aswell
u'll need...imo ...to open up the rear around the pipe as i did on my body?
That's normal . Mine is also close to the servo but is not going to damage your servo at all. The exhaust will slightly touch your body and you need to use heat resistant tape like i did.
I used this but I am sure they are cheaper ones on Amazon.
Heat-Shielding Aluminum Foil Tape, 2" Wide, 15 Feet Long
https://www.mcmaster.com/7613A42
Thank you Jshaff16 and everyone else, lots of good ideas. You guys are Awesome. Just did a couple off heat cycles on my OBR Engine. Running great. Just going to paint and use heat wrap. Should be fine.
Also do the shoe goo mod. It will protect the body from cracking and also protect your paint. Afterwards you can apply heat tape. Definitely worth it.
Thank you niz55, that's what I'm going to do thanks for your help. :):)
I must be the odd one out...didn't do anything above and beyond. Different pipe tho
I just ordered a roll from ddm, thank you Jshaff16 for sending me the link. :):)
I was going to start a new thread but i did a search and found this thread and i have come across the same issue's as the OP using the Victory Pipe although mine is shaped different towards the end of the pipe, with mine taking of the "exhaust header" will require a grinded down shorten hex key for the right side bolt it looks to be a a obvious tight fit.
One could replace the bolt with a stud, flat washer, lock washer and a nut. I'm not sure the exact length of the stud should be. Once you determine the length of the stud, use red loctite to install it on the cylinder head and let it fully cure.
