Losi 5t 2.0 double steering single servo?
Push/ pull you mean? Many have done it, personally I think they help but it isnt a huge upgrade.
They in my mind are easier on the servo, but I haven't seen one fail from your standard setup yet either.
I have lol
Seriously unimpressed with the plastic servo saver. It's virtually impossible to adjust and then as you drive it loosens up. Plus it's just. poop. It's my next upgrade
I have lol
Need to check it over, never had one loosen on me. So many racers use a standard servo with a standard setup with zero issues.
Single servo with stock wheels is really not a big deal Or if only bashing/ racing in tight dirt and asphalt ???
But running in Tall grass or really loose dirt, mud. The single servo really struggles
Add aluminum wheels and Hostile nobbys to the mix and the single servo will really struggle
I upgraded my steering servo to a Hitec 845 and it was a major improvement overall but it still lacks power☠️
if I had the right tools to drill some new holes and counter sink them right. I would slap on the dual servo tray from the 5B with 2 - 845’s for the win ??
I bought the Irwin set off Amazon for $35. Other than that just need a drill bit. Well worth the upgrade so far
Is the 845 a direct drop in replacement for the stock servo?
