Motor keeps dying when braking. Help!
Oh for FS Z stay on topic. Sticky to check proper throttle brake linkage function. Id say its going to be lengthy. Lots of variables.
1. Did you put the servo horn on when the servo centered with the radio on?
2. Anything binding?
3. Is there not enough travel?
4. Is the linkage not allowed to go all the way back due to spring pressure?
5. Did the linkage stop move?
6 . Did you cut your silicone tube to the right length
7. Does the battery have enough juice?
8. Servo end points
9. Is the servo getting full travel.
10. Is the servo weak
11. Is there something sticking in the carb
12. Is there any play in any of the levers the linkage sits in
13. Reset carb with linkage disconnected and off the ground
