My ESP 34cc engine seized on first startup
That's the issue. Loosen the bolts that hold the coil, take a business card that's paper and put it between the coil and flywheel, adjust it with the magnets right under the coil. Keep pressure down against the coil when you tighten the bolts.
Also push those killswitch leads down more on the coil spade connectors, their about halfway down.
Is that what they call the "air gap"?
Yea something to that nature, is it a stock clutch or fid you get the fs clutch? It makes the truck have more snap and pep off idle when you whack the throttle. There's nothing wrong with it.
It is the stock clutch that came with the ESP 34cc race ported motor i got from DDM. I have a Taylor RC machined intake with ramair filter and a Victory RC unsilenced pipe on it. This weekend I'll take it out and tune the high jet. Besides following the instructions that came from Doug, do you have any recomendations for the high jet tuning?
Then that's a 6k clutch maybe? I'd have to go back and check the description. Dougs tuning instructions are good, you can tweak it a bit more but check the plug to see if it's a nice brown paper bag color
