My HPI 26 Baja 5b SS
well 1st bash since front end rebuild...:p20190106_143100 by evssv, on Flickr
did find the rear fan brace bolt snapped 20mins before I was getting picked up....:rolleyes:....managed to get it out and find a replacement in time:p20190106_183531 by evssv, on Flickr
ran well until me rear left came loose..after only 5 mins......:rolleyes:.....luckily I took me wheel wrench...then the wheel nut stripped....:mad:.........so I used a business card split in half ..wrapped it round the hub...then screwed on the monkey nut.....it held tight for best part of a tank........:p
u can jus see it behind the nuts.....20190106_151858 by evssv, on Flickr...
then this happened ....again....:rolleyes:...
20190106_162724 by evssv, on Flickr
the kold cutters give too much grip o_Oand the rims jus twist off the hubs eventually....2nd one I`ve done now....:ROFLMAO:.
20190106_162712 by evssv, on Flickr
also killed the rear roll cage bit aswell....jus behind the roof plate.....:p
20190106_162834 by evssv, on Flickr
thk I need to find sum solid disc rims for the studded tyres..:unsure:
Sweet! So do you have the replacement parts on hand or do you need to order?
spear wheels.....hhmmm....possibly.....:ROFLMAO::ROFLMAO::ROFLMAO:........jus looking for roll cage bit now on rcmodz,,,,,,(y)
What did u do with both of your hands ???
the thread from last night/early hrs this morning....:ROFLMAO:..I`m sure doug will remember....:ROFLMAO:
So that leads me to my next question. Should I hunt down a genuine HPI or is the KM close enough if i am going to upgrade everything?
from what I`ve seen/read overthe last few years the km`s r now on a par with hpi plastic wise......(y)...and ur gonna upgrade as u bash/brake so don't really matter what u start with imo..(y).only got 5-6 hpi parts left on mine now.....:oops:if that........:ROFLMAO:......
Cool!
