My project
Ride stance.
And then you take that body off and there is all that emptiness. That roll cage got to go or grow up and fill up the front space, lol!
you make me want to take out all my parts from my redcat rampage xr rally and build something like that :O
what did you took for the frame? alluminium ?
Got delivery
Box 1 Jetpro MCD V4 pipe
Box 2 ... I didn't even get to it yet. Reason being that unfortunately the jetpro pipe doesn't fit. The loop in the back is too high and wide out. Bummer... Emailed Dino@jetpro, will see what happens.
meanwhile...
Box 2 from DDM
Walbro 990 (deal of the day) and some other stuff including this huge NRP wing
baja 5b vs NRP wing
Problem solved (theoretically). I'm moving the whole center drivetrain including the engine and gas tank 20mm to the right.
With which tools do you cut your aluminum? Sorry I don't kbow aluminum at all..
Sorry I didn't see your post. I cut it with a bandsaw. A jigsaw works too but it's harder. The key is to find the perfect blade with the best TPI (teeth per inch). I tried several one before finding the best one as the thickness of the aluminum also affect the appropriate TPI.
Wow thats a really nice project.
Hats off sir!
You may want to upgrade your front and rear diff housings. With those tires and that chassis, youre gonna destroy them.
Or a better idea, since you have a machine, fabricate one that uses MCD RRv5 diff cups and CVDs.
