Thanks TONS Trip. I never noticed the 2 different type compounds on it. I switched them and it sure made a difference. I can pull the wheels off the ground now thanks to you. I also have been reading some other threads and removed my rear sway-bar and I also could tell a difference in the handling. This is an Awesome site. I'm glad I found it. Nice group of people, so far, lots of info. Thanks again, Ben
hey Trip, just noticed your in Michigan. Where bouts?
That is a TGN on an FG, TGN made it for the Monster truck, i was wondering if the Firehammer MT was close enough to the FG monster truck that the pipe would also fit the Firehammer MT?
TGN is the only pipe maker that claims boosts to low mid and high with there Baja Race pipe. I was wondering how much did you see on the top end compared to the stock can muffler, i want lots of low end but i don't want a turtle slow buggy either. About 40mph is good enough.
heh. no that area. theres a track going up in Jackson area at a Baja guys place.
not sure if the TGN race pipe will work with any FGs, as it was designed for the Baja. its a hella low end pipe. has pretty good mids and decent high end too.
theres a shitload of us going out to silverlake dunes the middle of june, the weekend of the 21st i think.
you think the heat from the clutch bell could be taking out the pinion gear? I was planning on putting the Cat 5 steel 16/48 gears on there, you say these will not fit? or is it the stock FG gears that will not fit?
Ive heard of the diff and gear trouble, i can see how that would happen if you left it the way mine came from the factory, the motor and transmission gear was totally sideways only connecting about have to the trans gear to the diff gear. I straighten it up and adjusted the mesh. it seems to be fine now. Ive seen why people have problems with the gears on there fgs if they drive anything like the dude in the Video on www.FG-hopups.com on the Firehammer page. that guy is just trying to kill the gears on that truck. Full throttle landings and donuts. ok back to pipes
So you think the TGN pipe may fit the truck i see that i will need to find a spot for the front mount, the front shock towers are different between the FGMT and the FHMT. other than that it looks like it will go, but im still worried about the body clearing the pipe i could end up with a total mess if my body gets onto the pipe as it is plastic and not lexan. My truck is the Smartech version of the many many clone FGMTs. Thats the only difference between my truck and the others is the thick plastic body. if that gets on the pipe i might end up with soup.
looks like i might have to dump the Smartech and get a used up FGMT from ebay, i cant afford a new one. That way there wont be any question about if it will fit or not, i will know for sure it will fit or if it wont.
I know the DDM pipe will fit either the top end or the torque pipe but i cannot deal with that loud pipe, we have gotten banned from every place we have found to run these things because of my cousins DDM pipe on his Baja Buggy.
well, thanks for trying to help maybe next time ill give you something you can work with.
