baja_killer
Active Member
- Reaction score
- 65
Bought Losi new in December, First tank went great impressed with the power and handling,
2nd tank i started getting issues near the end of the tank started to raise RPM's uncontrollable which caused the truck to speed up with very little control and forced me to use kill switch to kill engine for safety. i assumed it just leaned out nearing the end of the tank.
3rd tank after starting engine up straight of the bat started to rev up and spin it wheels luckily i always use a stand when starting so wheels were off the ground! i adjusted the the idle screw which seemed to work and back down to a normal idle, during the run that day it started to do the same thing just revving up on its own even when braking! i ended the session early and called it a day as i'm completely stumped.
started it up again on my work bench and it's doing it again! its the same sort of situation you'd get if the throttle was sticking open but its not when i let the trigger go its running away its self even through braking only when i open throttle up full a few times and brake couple of times it goes back to idle but the idle is very inconstant!!
Completely stuck i'm just wondering if any of you guys have experienced or know how to resolve the issue any pointers.
Thank in advanced guys.
P.S. i have a video but i don't know how to upload
