- Maryland, USA ??
Yes. Its a 34 modded right? Your needle settings seem a little on the lean side. Usually with a modded engine you need more fuel.
Yes it's starving, sounds like it's running out of fuelWould this cause the problem of the engine cutting out under throttle?
Haha it’s only ran for like 45 seconds. The low should be up by 1 5/8?And thats your rebuild right? Sounds like she's itching to be rebuilt again bruh.
im not too fussed about it. everything will always get sorted in the end. they are all just learning experiences with some being very expensiveGlad you got it sorted ??
just spoke with dan from obr and realized that I installed the reed valve upside down ? told you guys there was a 50% chance I fiddlesticked something up
Did you ask Dan anything bout the website being down
nah its midnight here about to go to sleep. I think one of the screw for the valve stripped when I was installing it so that will be another mini project to flip it around. I would pay big bucks for hardened steel hardware btw.You had it on the top didnt you lol. Glad its sorted, were you able to run it to .make sure all is good?
yes and I also asked him what he was wearingDid you ask Dan anything bout the website being down
