- Nj
Baja 5t front is the same as Losi 5t front and rear so yes it should work .I've seen the proline desperado rims for the hpi 5b/5t... will the front "designated" wheels work on the losi 5t? Its a simpler design than the 2.0 design and its cheaper than losi branded wheels. DDM states that losi 5t hardware and bead locks work with these so its a step in the right directionView attachment 65421
Keep an eye on the metal insert around the hex if they fall out the hex will stripthose look good ..how is the wheels holding up? I would assume its the same material as the desperado.. im only asking because I came across a picture on Google images and it cracked pretty bad but it was probably user error
