- New Jersey
I'm doing an experiment and am wondering if the g320 crankcase works with the rovan 45cc or atleast 36cc engine.
just had a look on rcmodelz site mate, looks like the 45cc only works with the 45 case,I'm doing an experiment and am wondering if the g320 crankcase works with the rovan 45cc or atleast 36cc engine.
I did a 32cc ESP/Zenoah Head on a Rovan bottom end and it works , as far as I can tel for a 32cc-36cc it should ???? work on 45cc NO IDEA ?@buzzkill just did something very similar and it worked
RESP Rovan ESP mod , I want Doug at ESP to port a stock Rovan head and test it LOL !!!Whatcha calling it @buzzkill
Hardly pissing anyone off. It's just that those motors are a dumpster fire so why waste time is my standpoint.RESP Rovan ESP mod , I want Doug at ESP to port a stock Rovan head and test it LOL !!!
Just to piss you guys OFF !
So far so good OH and Im changing the name to #Donnydeath2020Hardly pissing anyone off. It's just that those motors are a dumpster fire so why waste time is my standpoint.
? Your username ?So far so good OH and Im changing the name to #Donnydeath2020
The Rovan 34cc and 36cc engines use a different crankcase than the 42 / 45 / 46 engines. Also all the < and including the 32cc engines are a different style crankcase than the 34 / 36 engines. I found this out when I was trying to find correct bottom end gasket / seal kits. The Rovan 34 / 36 cc engines use an oddball case.I'm doing an experiment and am wondering if the g320 crankcase works with the rovan 45cc or atleast 36cc engine.
Do it do it do it?Ok I think I learned how the crankcase scheming works after viewing this of all places. https://www.davesmotors.com/Products/Complete-Engines-and-Engine-Parts
I'm thinking about starting a youtube channel. My first video is gonna be extremely interesting. Let's just say "big power on the cheap".
Goo on son get in there?I did a 32cc ESP/Zenoah Head on a Rovan bottom end and it works , as far as I can tel for a 32cc-36cc it should ???? work on 45cc NO IDEA
Have to measure when I get home. Although I'm more interested in bolt spacing for the 45cc. Tell you what I'll measure mine. You measure yours and well swap numbers ?Ok I have one more question. Only the most experienced engine builders may know this one ?. What is the top end bolt spacing in the g320?
soooo, just had a measure myself,Ok I have one more question. Only the most experienced engine builders may know this one ?. What is the top end bolt spacing in the g320?
I was referring to a different top end that may be able to be used in the rovan case. I'm sure @spents got the measurements spot on. I just can't get past the crap open transfer design. Much better top ends exist imo. I just didnt want to buy a case if it wasnt going to work.Yeah gimme measurements guys. Make sure its right. Im making custom parts and might wind up with a custom engine if possible.
