RcJunkie TLR 5b
Just wanna share this cool trick I learned. If a screw has too much locktite use an impact drill. Instead of stripping the screw it will break the locktite lose. Also, when you are using an EZ out on a screw with too much locktite do the same for a much higher chance at getting the screw out. Make sure you use a good bit such as MIP do it does not break. (y)
