Rear hubs
DougStar
Well Known Member
PLUS member
Build Thread Contributor
Crafers South Australia
Looking at get a set of hostile hubs .....there is a lot the to choose from ?? 0 degree ,2,3,4 or adjustable hubs? on my losi I run 3 degree.....so I'm thinking 2 or 3 and not the adjustable ones cos of the inserts needed (wear items that may get hard to find)
I assume the insert is rubber or plastic? Could make a few out of aluminum if you ever were super worried about how long they would last.
-2 to -3 is the norm.
depends on what surface you mainly run on? if its grass you can get away with less as you have more grip. the looser the surface the more bite you need.
however the more -camber you use the less power will be put to the ground in a straight line.
I have always ran -2 on my Baja's in the past.
