The punisher
Pretty easy to stretch and widen the truck with available kits out there. My concern is around drive train. I see that eating transmissions like the RC Max 80 wants to do. I do like the fact the pipe is primarily contained in the body, just losing the driver vs sticking out the back of the bed. Keeps more of the true Monster Truck look.
I like the pipe placement better as well, but the stock body looks like crap imo. Really not a dodge fan. They should have offered it with a grave digger body or something of the like, would have appealed to a larger segment of buyers. (Also my opinion)
The second video is Aaron from bebop rc's ram and is the 71 performante. Alx said they are coming out with more engine pkg options. I agree it way too much. It would get very old quick not being able to control it and keep the front down. I do like the pipe tucked in the cab more as well.
I hope they will come out with more bodies too!..I can't knock Darge though as I have one and this ones been good to me for the 4yrs I ve had it and have had all of generations. I have had every brand HD truck and come to the conclusion their all junk!🤣
Licensing is an issue for trucks like Grave Digger and such....especially since the bulk now are owned and operated by Feld Entertainment, folks who own Monster Jam. I do know in the fall we will have another body option. From what I have been told it will be along the lines of a 80s style Chevrolet or Ford. Which makes me think it will be something close to a Clodbuster type body look, that is my speculation. Have not been able to squeeze much more out of Primal on it. If Monster Jam worked w Primal and released a series of Monster Jam bodies...I would end up bankrupt lol! 😂😂
I've had or put tons of miles on every version up till 07 yhen skip to 19 dodge cummins. Only part of the truck that was worth crap was the engine imo. The 90 was just a crappy truck in general truck rode terrible. So bad in fact I hit a rumble strip and the radio fell out of the dash. Spent big money on air ride seats for it helped a bit. Forward to 94 truck litterslly fell apart in 6 years. Entire interior was just built like garbage. Auto trans was a constant issue, ended up swapping a 5 speed. Front axle was a rebuild every year. Frame cracked at steering box, brace and welder fixed that. 24vaoves were hit and miss with the 53 block, the trucks were the same trash ad the second gen trucks. Now I've been in quite a few third gens. Trucks were better, then previous modes, but not by much. I think they rotted out a lot faster and the auto trans were still garbage. The 07 was a nice truck inside, I personally put over 200k miles on it. Interior didn't fall apart like the earlier trucks, front end held up better, but it was also 2wd. When it did need rebuilt it was one thing right after the other, with in 2 years every thing had been replaced. The truck ate power steering pumps for some reason. The last one it blew up the dealer replaced literally everything that the power steering pump fed fluid to. Hydroboost all lines, cooler, box, tank and all lines. I quit shortly after I took all that work so I don't know if it lasted, I suspect it did. The 6 speed manual wad garbage as well. Towed very heavy with that truck and quite often, they never should have used an alloy cased trans in those trucks. The 19 we had was a dead dog worse then the 07. We had it back at the dealer several times and they just kept telling us it's normal. Our old 05 f550 litterslly would kill it in speed and towing power. Kinda sad when the 6.7l cummins was rated nearly 100 hp and a lot more torque over the 6.0l ford diesel. I have a few duramax stories as well, but other then the normal extremely weak front ends, it wad typically Nickel and dime bs with them. Just the same crap all the time, and the frames didn't particularly like when you hated heavy with them for a few years, but over all held up better then the dodges in the 2005 and up trucks (whenever they switched to the slanted head light body style) always rode good, and had pleasant street manners (when the front end wads working right) but felt like a cheap truck, especially when compared to the same year ford's with a similar trim package. The duramax had quite a few issues in the early years as well, but seemed they hammered those issues out in the falling generations. Sucked balls off road around the mine sights, don't know so much why, but then again I never felt like it was competent at towing either, just never got the power to the ground quite right, very quick to spin out. Not a terrible truck overall though. Out side of quite a few years with a garbage diesel engine I don't have major complaints with their trucks, I actually wish the other companies made trucks that would compete as far as durability. Of the truck it's self. You'll be hard pressed to find an early 2000's for who's interior is completely falling apart just from old age. The rot on them seems just as bad or slightly better then the other 2.
