Vesla Big Bore Trans Upgrade
cmbscx10
LSF Plus Member
PLUS member
Ramona, CA
Looking to go either a Taylor RC 35V2 Reed or a Taylor RC 50GT for a Christmas present to myself. No matter which motor i go with i want a Big Bore Trans for near bulletproof performance.
The question is which one to piece together
1. Taylor RC Big Bore w/Taylor & Blackbone Baja gears
2. Kraken RC Big Bore w/ Kraken Hardened Gear Set
3. Kraken RC HD w/Taylor & Blackbone Baja gears
Has anyone gone the Kraken RC Big Bore route using the kraken gears? I have read the the Kraken HD version with Taylor layshaft, idler and Blackbone Baja gears works well.
$$ is always a concern but at this expense a few $$ difference is not noticed IMO. Thanks for any input
A 1000 thanks for the input so far.
I watched Crucials YT video. He is/was using the Kraken HD Trans Case but i can't remember the internal gears. He smoked that pretty quick
Meyer's 2 Stroke RC Garage uses the Kraken HD Trans Case, Taylor idler and Layshaft, Blackbone Baja gears but i can't find what the internal gears are. He had a Taylor 35 with no issues and went to a Taylor 71 with no trans issues but smoked a flew clutches.
I read a little more on the Taylor BB Trans Case and the 3 piece vs the Kraken BB 2 piece has me almost sold just due to maintenance.
Depends how old the build is, there was no optional internal gears when released, then kraken made hd trans and diff gears, then taylor made a hd idler gear ... the ilder gear is tiny compared to a baja and baja case not compatible so far
True. I just started researching and seeing who is using what with good or bad success.
I am not seeing a Drive pinion or Diff gear upgrade from Taylor (save for the Idler) so to use his trans i am researching if the Kraken Hardened BB gears would fit his case.
