John Parks
Print my own
I want them for my baja,I was just suggesting for test of strength. My best bet is the genesis paddles and everything else is for show
What engine is going in that baja again?
I'm still undecided after watching Corrados vid, the Diablo is almost annoying to even watch in a baja. so I'm not sure how that 96 will beWhat engine is going in that baja again?
True friends always suggest the worst idea firstOutlaw build is a terrible idea, that weights easily 50 pounds. Plus I don't feel like throwing foams and tires in the trash from blowing up
Danny runs them on his vekta and jumps the hell out of them with what looks like no issues.Outlaw build is a terrible idea, that weights easily 50 pounds. Plus I don't feel like throwing foams and tires in the trash from blowing up
No $380 issuesDanny runs them on his vekta and jumps the hell out of them with what looks like no issues.
Where do you order Vitavon stuff from?
Good to know. Thank you. Yes I’m in the states.If your in the states, Danny liew on Facebook
Cool, thank you.From Facebook or ebay
50lbs RTR is spot on, but i bet a Baja isn't much less when you add all the alloy, FLM arms, etc etcOutlaw build is a terrible idea, that weights easily 50 pounds. Plus I don't feel like throwing foams and tires in the trash from blowing up
I made a thread for that50lbs RTR is spot on, but i bet a Baja isn't much less when you add all the alloy, FLM arms, etc etc
**edit** that sounded so n00bish
I mean an all alloy Baja, but of course it can be built much lighter, where as the Outlaw is what it is, and you can only shave a little off the weight here and there. Still gonna be around 45lb minimum
Oh ok, that much lighter even when fully decked outMah, baja is actually almost 10 lbs lighter fully decked out. 42lb for my bigbore baja with a steel cage, most are actually around 38
Super nice craftsmanship. Are there any pros of allot wheels compared to the stock ones? I understand they may be stronger but anything else?
The gold ones look greatI'm just not sure bout the 1.8 kg before foams and tires they do look super bad ass but
